Screen shot of a 3rd party software
A 3rd party software is running in my PC. The display shows reports of components passed or failed and the condition of failure etc. But this report cannot be retrieved as no local copies are stored. For my reference I would like to
1. capture the screen after every update.
2. Retrive the data and write it to a excel. (Is OCR an option?)
Any light on this will be very helpful.
Message 1 of 14
(3,568 Views)
Hi muks,
it should also be possible with windows API. You can get the handle of the control which stores the pass/fail information and read it from there. If this is not possibe, you can use this code to get the image you need:
http://forums.ni.com/ni/board/message?board.id=170&message.id=311290&query.id=1125687#M311290
Mike
Message 2 of 14
(3,558 Views)
Hi mike,
Thanks for the reply. But the program crashes labview. "Labview encountered a problem and needs to close". I tried it with the lv 8.0 version in the thread. Do you think my lv is corrupted?
Message 3 of 14
(3,546 Views)
Hi muks,
it works for me, but here is an alternative. It only reads the image from the clipboard.
Mike
Message Edited by MikeS81 on 06-18-2009 11:05 AM
Message 4 of 14
(3,537 Views)
take a look at a program called macro express for automating something like this.
http://www.macros.com/
http://www.wintools.com/automation.htm
Message 5 of 14
(3,533 Views)
muks wrote:
Hi mike,
What is your LV version? Can you post here a screenshot of you LV crash?
- Partha ( CLD until Oct 2027 🙂 )
Message 6 of 14
(3,520 Views)
AS I mentioned I am using lv 8.0 .
Message 7 of 14
(3,507 Views)
Hi muks,
can you work with the vi from my second post?
Mike
Message 8 of 14
(3,487 Views)
I think you did not... Smiley Happy
muks wrote:
Hi mike,
This is why I asked what your LV version is... Smiley Wink
Message 9 of 14
(3,460 Views)
In all the subvis I get this error and when i try bypassing the error connection labVIEW crashes.
Message 10 of 14
(3,414 Views)
