Screen shot of a 3rd party software
Hi muks,
delete these wires. You get this because in LV80 the call library function node hasn't an error connector. I created these vi's with a higher version and saved it for previous use. So you have to clean the broken wires.
Mike
Message Edited by MikeS81 on 06-24-2009 10:27 AM
Message 11 of 14
(619 Views)
That is exactly what i did and it is crashing my lv.
Message 12 of 14
(616 Views)
Hi muks,
sorry for this. I'll check it in the evening, and if possible i send you a running LV71 or 80 version.
Mike
Message 13 of 14
(611 Views)
Accepted by topic author muks
Hi mike,
Solved the problem. The write to bmp was creating the crash. So I replaced it with getclipboard image. In addition I changed a couple of things in vi properties and It is working perfectly fine. Thanx a lot for the help mike.
Message 14 of 14
(603 Views)
