Screenshot taken by software is giving different colour of front panel
I have a vi which takes screenshot of the front panel, the problem I face is that the colour of the front panel and that of the jpeg file is not the same,
Kindly guide me.
(1,412 Views)
Accepted by topic author msabah38
Hi msabah,
why do you name that VI as "LV2013…" when it is actually saved with LV2019?
Did you set the correct color depth when saving the image as JPG?
(1,394 Views)
sorry, please find the previous version here.
(1,385 Views)
You should set the image depth of your invoke node to something else than the default value.
Regards, Jens
Kudos are welcome...
(1,373 Views)
Thanks, changed the colour depth to 24 and it worked.
(1,369 Views)
