Script Error when click on Find Example in LabVIEW Help
I was able to report this problem to National Instruments using the "Report a bug" link below. Hopefully they come back with a "bug fix".
Message 11 of 69
(7,474 Views)
I already placed an entry in the Monthly bug thread and pinged some channels.
Since it seems to be broken on many OS and LabVIEW versions, it seems likely caused by e.g. a windows security patch or similar.
Message 12 of 69
(7,463 Views)
@altenbach wrote:
... it seems likely caused by e.g. a windows security patch or similar.
That would make sense, since the PCs where I don't see the problem are "embedded" and all updates are frozen.
Message 13 of 69
(7,454 Views)
We have filed CAR #718419 to address this issue.
Thanks for bringing this to our attention!
Message 14 of 69
(7,448 Views)
How/where does someone access the status of CAR #718419 ?
Message 15 of 69
(7,445 Views)
It is not public.  About all you can do is watch for it in the LabVIEW release notes.
Message 16 of 69
(7,438 Views)
As suggested by @altenbach, windows update KB4462919 seems to be the problem:
https://support.microsoft.com/en-us/help/4462919/windows-10-update-kb4462919
After removing this update from my Windows 10 computer LabVIEW help finally works.
Message 17 of 69
(7,434 Views)
@altenbach wrote:
I actually noticed this a while ago, but wanted to investigate first. Thought it was something local since nobody else seems to mentioned it. 😮
  • It does not seem to matter what the default browser is (tried Chrome, Edge,  IE).
  • Running as administrator does not help.
  • Disabling AV does not help.
  • Yes, thing work if I open the chm file from within windows explorer.
  • It also works if I open help chm file using "control online help" (e.g. using <helpdir>\_LaunchHelp.vi)
  • Either LabVIEW calls the help incorrectly or there is a permission issue somewhere.
I never noticed it until a few days ago because I only rarely click on anything in the help file.  I mostly use it to remind myself of all the nuances related to something already on the block diagram.
Bill
CLD
(Mid-Level minion.)
Message 18 of 69
(7,429 Views)
Many times, the forum topic where the CAR was first reported as being created will be updated when the bug is actually resolved.  So don't be surprised if, a few years from now, you get an email saying there was a reply to this topic.  😄
Bill
CLD
(Mid-Level minion.)
Message 19 of 69
(7,425 Views)
The KB4462919 windows update which was the "root cause" of the problem on my computer was dated 10.10.2018.
Message 20 of 69
(7,423 Views)
