Scripting - Array Constant
I am familiar with LabVIEW and have been fumbling my way through scripting in order to develop a few vis that need to be dynamic.  I am attempting to generate an array constant in the block diagram.  So far I have gotten closest with the following:
The problem is that when generated the array is empty and does not contain my test of string elements (a, b, c).  This is the outcome:
Any feedback as to why the created vi is empty would be appreciated.
Lastly, a more general question.  Working with scripting has been a bit of a trial-and-error situation.  Is there any documentation available that might help learn this?  Thanks.
(2,491 Views)
Accepted by NI_User_11108
I ended up getting this working with the following, which makes sense since I couldn't assign the value prior to the type:
My question still remains on any scripting material.  Thanks.
(2,471 Views)
Good that you find the answer, just sharing my old module.
You can find few basic documentation here- VI Scripting - NI , also you can find more such modules in NI Examples (Scripting).
(2,442 Views)
