Seamless Generation of intermittent patterns
I'm using a 6562 device for generation of clock and commands for an ASIC.
I need two clocks generated (say 100MHz and 50MHz) as well as the commands for the chip. The commands are not send in a continuous manner, though the clocks shall be seamless.
I would like to use CLKOUT line as the faster clock, DIO0 line as the slower one (1010101010...) pattern with 0s on DIO1 (used for command line)
I would like such pattern to be output constantly, with occasional burst of some given waveform on DIO1 (bundled with DIO0 'slow clock' pattern). How  do I seamlessly inject some arbitrary (known beforehand) waveform inside a continous generation of 'clock'?
(2,642 Views)
This is a great application for scripting. The 6562 (and other HSDIO devices) have a scripting functionality that allows you to download multiple waveforms and then define loops, links, jumps, etc. With scripting you can download an "Idle" waveform that generate a constant clock and other waveforms that generate the clock plus the commands. After writing the waveform you write a script that loops you idle wavefrom until you send a SW command or a HW trigger to jump to one of the commands. Jumping between waveforms is seamles and you will not miss any samples. Check out the Script Editor at "Start>>programs>>National Instruments>>NI-HSDIO>>Script editor" to get a better idea of the different functionality offered.
Good luck with you application,
Juan Carlos
(2,611 Views)
Thank you for your prompt reply,
 Looks almost like the script triggers would do the job, though programming 4 available script triggers to provide the chip with some 50 different commands seems kind of difficult :). I have realized I may use external signals to control the script thanks to your answer, though I have still to check if I may somehow switch/overwrite a waveform in device memory when other one is being generated...
Message Edited by mdwuznik on 12-03-2008 08:38 PM
(2,593 Views)
