12-03-2008 05:44 AM
I'm using a 6562 device for generation of clock and commands for an ASIC.
I need two clocks generated (say 100MHz and 50MHz) as well as the commands for the chip. The commands are not send in a continuous manner, though the clocks shall be seamless.
I would like to use CLKOUT line as the faster clock, DIO0 line as the slower one (1010101010...) pattern with 0s on DIO1 (used for command line)
I would like such pattern to be output constantly, with occasional burst of some given waveform on DIO1 (bundled with DIO0 'slow clock' pattern). How do I seamlessly inject some arbitrary (known beforehand) waveform inside a continous generation of 'clock'?
12-03-2008 09:39 AM
This is a great application for scripting. The 6562 (and other HSDIO devices) have a scripting functionality that allows you to download multiple waveforms and then define loops, links, jumps, etc. With scripting you can download an "Idle" waveform that generate a constant clock and other waveforms that generate the clock plus the commands. After writing the waveform you write a script that loops you idle wavefrom until you send a SW command or a HW trigger to jump to one of the commands. Jumping between waveforms is seamles and you will not miss any samples. Check out the Script Editor at "Start>>programs>>National Instruments>>NI-HSDIO>>Script editor" to get a better idea of the different functionality offered.
Good luck with you application,
Juan Carlos
12-03-2008 01:36 PM - edited 12-03-2008 01:38 PM
Thank you for your prompt reply,
Looks almost like the script triggers would do the job, though programming 4 available script triggers to provide the chip with some 50 different commands seems kind of difficult :). I have realized I may use external signals to control the script thanks to your answer, though I have still to check if I may somehow switch/overwrite a waveform in device memory when other one is being generated...
