Search a value in a database and return all the valuesin a line of the table
I want to be able to search a unique value in a table of an SQL database and if the value is found, I want to be able to return all the values in the row of the table in the database. I want to be able to manipulate each value in the row separately.
Can someone please give me an example, because I'm new to labview and I don't know how to do this.
(3,509 Views)
Do you know how to make an SQL query in LabVIEW?  It sounds like "SELECT * FROM [a table] WHERE [a field] = "a unique value" will get your row.  What have you got so far?
Jim
(3,491 Views)
I like to use the Execute Query function:
Jim
(3,483 Views)
Today's fun fact - dropping this snippet on a Block Diagram crashes LabVIEW 2013 every time for me.  Does anyone else see this?
Jim
(3,468 Views)
I don't have LV 2013 on this machine to test, but it did crash LV 2014 on me.
DAbort 0x1A7102DF in fpsane.cpp
That points to the front panel.  But one thing I find odd about your snippet is that the string constant is partially cutoff.  I thought the CCT would always grap the entirety of any selected objects.
(3,464 Views)
I intentionally didn't select any of the string constant.
Jim
(3,439 Views)
Instead use select. In the coulms input you can mention coumns name you need. Output will be 2D array. Change and manipulate as per your requirement
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
(3,432 Views)
