Search and replace substring
I can't make the function Search and replace string work. I attached an image of the code and the string I receive. The function retrurns always 0 replacements.
I replace the substring with an identical substring because I only want to know if the substring is present in the whole string I receive and I can't find other useful functions.
Thank you
(1,162 Views)
Maybe you need to set Multiline to True
Qestit Systems
Certified-LabVIEW-Developer
(1,128 Views)
can you post your entire and exact input string? Because it works find here (I used a different but similar input to yours). Match Pattern also works if you want to try it.
(1,116 Views)
Accepted by V.Life
I managed with Match Pattern
(1,097 Views)
