Search by keywords in the ring
I have a list of many user to store information. I put them into the array string and use the Ring to be able to choose which user i want. But I had a hard time with too many users, which made it very difficult to access. Is there a way to search by the elements in the string and give the fastest results?
Thank.
Message 1 of 8
(3,578 Views)
There is no built-in search capability of a ring control.
You could add the function to the owning VI, or design an XControl that has that capability.
Message 2 of 8
(3,565 Views)
So sad. My current level cannot add functionality to VI ownership or XControl design. Currently I am using the vertical bar to search for users. My user list is getting bigger and bigger, I can't use this method forever. Can you guide me to do the above 2 ways?
Message 3 of 8
(3,553 Views)
Check out Darren's nugget on building the quick drop functionality.  Maybe something here will help you.  tst also posted a link to his code that does autocomplete.
aputman
Message 4 of 8
(3,551 Views)
thank you, i used combo box in string function.
Message 5 of 8
(3,460 Views)
Message 6 of 8
(3,455 Views)
This CLA Summit presentation (around 5 minutes) might help you - it's not exactly what you want (I don't think) but it's pretty darn close from what I understand:
The Little Things in LabVIEW 2020 by Darren Nattinger
GCentral
Message 7 of 8
(3,452 Views)
Thank you for comment. Darren's way is great but I need to use it when running vi, so I used the combo box, it fits my program very well and I found it to be similar to ring and enum but it is searchable
Message 8 of 8
(3,445 Views)
