How to split a 2D array into two 1D arrays
I'm trying to split a 2D array like array 1 in the photo below into two seperate 1D arrays like array 2 and array 3. What function will allow me to do this?
(4,075 Views)
Accepted by topic author benm92
Index Array
Drag bottom border downward to get 2 outputs.  Wire a constant of 0 to the Column input of the top output.  (Column 1 will be automatically chosen if you leave it unwired for the bottom output.)
(4,069 Views)
