Search excel file, return value from different column
You are not closing the sheets, workbook and workbooks references. Before closing the _Application reference you can use the Quit method to exit Excel. Also, as I said in a previous post the reference should be closed in the reverse order they were opened (i.e. _Application reference: first open, last close)(worksheet should be closed before _Application).
Ben64
Message 11 of 12
(1,308 Views)
ben64,
Thank you so much for your help and sticking with me. It works perfectly now. Take care!
Message 12 of 12
(1,305 Views)
