Search for Conditional Disable Symbols
Is it possible to search for all uses of Conditional Disable Symbols in a large project?
Joel
(5,456 Views)
Accepted by Joel
Ctrl+f
Jim
(5,454 Views)
Accepted by Joel
Yup search.  I'd like to add a fun fact.  If you select an object on the block diagram, then press CTRL + F it will be the item to be searched for.  So you just need to select any conditional disable diagrams structure, then press CTLR + F to find them all.
(5,449 Views)
Thanks for both solutions
(5,432 Views)
Note that the Find dialog requires all the VIs in your project to be in memory. If you want to search a folder of VIs for calls to the Conditional Disable Structure, without requiring all the VIs to be in memory first, you can use the Find Function test, available as a community download from the VI Analyzer Enthusiasts community on ni.com. That page also includes instructions on how to install and run a custom VI Analyzer test. Note that using community tests does *not* require the VI Analyzer Toolkit to be installed.
If you end up going this route, just specify a function name of "Conditional Disable Structure" and you're all set.
(5,423 Views)
...Note that using community tests does *not* require the VI Analyzer Toolkit to be installed....
Never realiized that.  Cool.  I'll have to take another look at the test list.
(5,407 Views)
If you are looking for a particular symbol, you can try to search for the text (sub)string of the subdiagram like : "MyCustomSymbol==TRUE".  I found this helpful looking for where a specific custom symbol was getting used.
(5,060 Views)
