Search sometimes highlights a blank area in the block diagram (bug?)
@thols
Yes, clean Mass-compile. (Apart form some expected errors of no-longer-called sub VIs with outdated typedefs etc).
Message 11 of 16
(611 Views)
There's a bug pertaining to the coordinates of objects inside a cluster (I don't remember the details).
The thing you're searching for might be inside a cluster constant.
Message 12 of 16
(600 Views)
Ah yes - I think it was inside a cluster constant!
Message 13 of 16
(584 Views)
@pincpanter wrote:
BTW, anybody knows what's that "Filter" half transparent text that frequently appears on the BD?
I was wondering about that as well.
Bill
CLD
(Mid-Level minion.)
Message 14 of 16
(582 Views)
I just started a new topic on my theory about the "half transparent text"
https://forums.ni.com/t5/LabVIEW/Random-Greyed-out-text/m-p/4275667
Former Certified LabVIEW Developer (CLD)
Message 15 of 16
(506 Views)
I think you might be just a few degrees off Paul.
The thread bothered me.....kind of like a "Spidey Sense."  I am pretty sure that I have never been bitten by a genetically engineered, radioactive VI but!...
Text search is the only way to find those silly BD object Lables that have been accidentally moved away from one of the nine snap justifications and then moved further away with a "make space".  Either by a intentional make space or a bad cleanup.  Call the label an orphan!
I think what is seen is the unshown text of a hidden label that is "Orphaned" from the owning object.  This CAN cause an object.bounds property to become irrational.   Without examining each and every object bounds there are few tests that can find an orphan lable.
The text search is one!  It can look for object labels even when hidden.  It does fail to identify the object it is part of though.
Basically, you have an indication of an irrational (not insane) Object.  I can't say it's a bug....more of a dev error identifier.
Find the object! Show the lable! Snap it back to some justification.
Lock labels by default if desired
Lable or label? F it whichever.
EDIT: Paul will likely have a vi by end of day that scripts out a search for orphan lables, shows them and rejustifies them to the owning object after adding garish coloring and additional derogatory remarks addressing the developer's probability for Darwinian competition success.
Kudos to you!
Message 16 of 16
(484 Views)
