Search string array for string subset containing special characters
@billko wrote:
And I forgot that Booleans aren't truly one bit; it actually takes 8 bits to represent each Boolean so thanks for reminding me about that.
It used to be even a 16-bit integer until LabVIEW 4.x. But boolean arrays were packed with 8 boolean values per byte. But that was changed in LabVIEW 5.0 because the packed boolean array was memory conserving but very CPU intense to pack/unpack and index.
Rolf Kalbermatter  My Blog
Message 11 of 16
(1,143 Views)
Did you have 8 booleans in 16 bits?
Qestit Systems
Certified-LabVIEW-Developer
Message 12 of 16
(1,100 Views)
@rolfk wrote:
...  until LabVIEW 4.x. But boolean arrays were packed with 8 boolean values per byte. But that was changed in LabVIEW 5.0 because the packed boolean array was memory conserving but very CPU intense to pack/unpack and index.
A side effect is that we still have that overlooked 4.x typecast mode that can be sometimes useful, but we need to remember that the index 0 is the MSB.
Message 13 of 16
(1,093 Views)
No. A scalar boolean was an int16 and an array of booleans was 16 bit padded.
Message 14 of 16
(1,073 Views)
Here's the proof that a scalar boolean was 2 bytes.
Message 15 of 16
(1,049 Views)
Cool. I like learning of the history, i first touched LV in ver 5 i think (very rudimental) and any form of advanced LV was 8.2 for me.
Qestit Systems
Message 16 of 16
(1,037 Views)
