Search third party USB device with vendor ID programmatically
I have a Crestron device communicating through USB and would like to search for that device using the vendor ID programmatically. Input is the Vendor ID and
the output should be boolean (found or not ) and a serial number of the device or USB canonical name.
Thanks in advance.
(3,217 Views)
(3,182 Views)
Either search the results for specific IDs, or narrow the filter. See Get-CimInstance (CimCmdlets) - PowerShell | Microsoft Docs
(3,171 Views)
 and kartiknattar,
Thank you so much for the responses. I have used the following method and that worked!!
Pratyusha.
(3,108 Views)
