Segger Flasher Compact V7.0
I'm trying to link to the Segger Compact V7.0.
I've used the following forum post: Solved: Using a segger's flasher 5 programmer in labview - NI Community
and have been able to get a connection to the Segger, sending #auto, #select, #project, etc.
However, I cannot find the solution to sending the project to the flasher.
Similar to this forum here: Using seggers Flasher ARM in LabVIEW - NI Community
Has anyone been able to find a solution?
Catherine
(842 Views)
Hi Catherine,
We typically start the JFlash executable with the "-openprj filepath" argument.
After starting JFlash with its project we do the ERASE/WRITE/VERIFY steps…
(825 Views)
I've been using the U-Flash commands: Flasher - Remote control - SEGGER Knowledge Base
This is because when I link to a MSP430FR2153, this isn't an option using J-Flash or J-Link Commander 'The selected device "MSP430FR2153" is unknown to this software version.'
In LabVIEW, how are you sending commands to J-Flash?
(810 Views)
Hi Catherine,
we use mostly Segger FlasherPro, connected by (local) LAN.
In LabVIEW the VISA functions are used.
(794 Views)
Accepted by CatherineBrown
I was able to find a solution using UniversalFlasher.exe.
I have attached the .vi that is working for me.
Catherine 🙂
(697 Views)
