Segmentation fault during unloading of advanced analysis library on Linux
I'm running LabVIEW 7.1 for linux on a gentoo box. (Yes, I know it's not one of the supported platforms, so don't bother telling me about it.) System details are included at the bottom of the message. I'm seeing a segmentation fault anytime the advanced analysis library is unloaded (whenever the last VI that references the library closes). Has anyone else seen this behavior? Presuming its the result of my particular system, does anyone have any idea which library may be at fault?
Further details:
The crash occurs several calls down from the call to __cxa_finalize, which I believe is responsible for destroying static c++ objects.
My system:
LabVIEW 7.1
kernel 2.6.14 (with gentoo patchset)
glibc 2.3.5
Jason
Message 1 of 1
(2,370 Views)
