Select cell in MS-Word table
How can I select a cell in the MS-Word through LabView when I'm using active-X? There should be a way to use the invoke and/or property node to select a cell in a word table directly. Which active-X class I have to use? Followed by..?
Attached I have an example vi ready.
Thanks for your help
                          Norick
(2,678 Views)
Just use the ActiveDocument property into the Tables property into the Index method into the Cell method.  This returns the reference to a single cell of the table.  See the modified vi.
Michael Munroe, CLD, CTD, MCP
Automate 1M+ VI Search, Sort and Edit operations with Property Inspector 5.1, now with a new Interactive Window Manager!
Now supports full project automation using one-click custom macros or CLI.
(2,670 Views)
Thanks for your reply. Do you also know how I can change or set the text from the header / footer in a active document?
(2,661 Views)
