Select data between cursors on a graph
So you want to leave out the white data at the bottom? What should happen if some data is only selected partially?
No I want to include the data of all the traces
Do all the traces really have different x-values that are randomly spaced?
I don't think the data is random.
It's coming from an array with 9 traces, where the data is stored ,in each iteration, from top to bottom.
I believe that in each iteration, the graph is replotted using the data from this array.
So in a way, it mimics a chart.
How do you want the output of the selection arranged?
I want to have an array of all the selected data in an Excel file, with each trace in a separate column and a column for the date and time of each measurement.
Message 21 of 25
(1,187 Views)
So, again, then you don't need the cursor y position at all.
Your full data is a 2D array and all you need to do is taking a 2D array subset based on the two cursors.
Writing a 2D array to file is trivial.
Message 22 of 25
(1,170 Views)
I tried to create a subarray, but it doesn't seem to work.
Message 23 of 25
(1,147 Views)
You need to translate your x values into array indices, of course!
Message 24 of 25
(1,129 Views)
Yes that's what was not working.
So I copied the code you used for the integral and tied the cursors to a random plot.
And it worked!
Message 25 of 25
(1,124 Views)
