Select folder path dialog box
Hello!
My program requests that the user select a folder (not a file), for a path that is needed in the vi.  I've modified the path control's browse options for folders only and it works fine, but the problem is that when other users run my program, they get confused and think they're actually saving a file.  Is there a way to change the pop-up when the control is clicked so it'll show http://concealedcreation.com/Documents/Browse_for_folder.gif rather than http://concealedcreation.com/Documents/select%20folder.PNG?
(4,003 Views)
Use this VI as per Ur requirement.
Rgds,
Partha.
- Partha ( CLD until Oct 2027 🙂 )
(3,989 Views)
Works, thanks!  Is there a way to add the "Make New Folder" button as well?
Edit:  Never mind, I found it myself.  Need to set the ulFlags option to 64.
Message Edited by AntLee29 on 02-08-2007 03:28 PM
(3,962 Views)
