norton antivirus and timed loops
I am currently running a timed loop at 100mS with some File I/O in it.  When Norton does it's weekly Virus Scan, the timed loop becomes sporadic.  Is there a way around this without excluding the file location from the scan?
(3,106 Views)
File IO with or without virus scanning isn't deterministic, so it would be in your best interest to put the File IO functions in a separate non-timed loop. Consider using queues to transmit data from the Timed Loop to the second loop to be written to file. This will buffer your Timed Loop from the perturbations in your system caused by the File IO and virus scans. Hope this helps!
Jarrod S.
(3,091 Views)
'some File I/O' every 100ms? Even when excluding your data directory from scanning this may lead to problems!
Modern harddiscs need 10 to 20ms for head positioning (aka seek time). When accessing 2 files in parallel (LabView and Norton!) you need ~40ms just for seeking operations. How much time do you need for your file io? Seeking file, finding write position, writing data, updating file system entries and so on...
I would suggest to redesign file operation!
(3,090 Views)
@Jarrod S.
"perturbations" -- nice word man!
Doug M
For those unfamiliar with NBC's The Office, my icon is NOT a picture of me 🙂
(3,054 Views)
