Select specific row from array, then subsequent rows based on input
I have an array that contains 2 columns.  I would like to pick a specific row from the array based on the entry from column 1.  Also based on the # registers input, to pick subsequent rows from column 2.
Here is an example:
For the above entries in the block diagram, I would like to get this output:  0102 followed by the 2 rows in column 2: 0001 1003.  The overall output will be 010200011003.
Any help will be greatly appreciated!
(2,007 Views)
Accepted by topic author hiNI
Index the 2d array by columns, search column one for match(es) and get the index/indices. Loop over the index/indices and get the array subset from column 2. Transpose array, or concat instead of index as desired.
(1,964 Views)
