Select text in a table cell
By tabbing or shift-arrow navigating a table, the cell text is selected. However, I can not figure out how to programmatically select the text of a cell for the user to edit.
_____________
Creator of the BundleMagic plugin for LabVIEW!
(3,805 Views)
Accepted by littlesphaeroid
Use a property node with...
1) Key focus = T
2) Active Cell
Ben
(3,789 Views)
Thank you, key Focus was what I was missing. I figured it was already the focus for my operation. I found that I needed to set Edit Position to get the cell contents selected. Looks like there's no way to set a cursor at an arbitrary position in the cell.
Thanks!!
_____________
(3,765 Views)
