Select vs Case Select
My question maybe a bit stupide but Im not figuring the error.
This simple vi should:
- count any paire number und
- build the sume of every paire number
in a given array. Only the select function should be used and not the case select.
Building the sume ist working but counting is not working.
I ll appreciate any advise.
(2,824 Views)
Accepted by Serikah
you made a small mistake, when the current value is not "paire" you select "0" and then add 1, it doesn't make sense.
what you need to do is add 1 if "paire" or keep the previous number
see this :
on a side note, it make more sense to use i32 if you are dealing with integers.
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
(2,813 Views)
Thank you.
That was my mistake.
(2,806 Views)
