04-03-2019 07:16 AM
Hello
I'm building a small tool that should help an operator copying a lot of different log files to the correct place after a test. Unfortunately one of the files is stored on an FTP drive. As the file name always changes and it might not be the latest one I need a browser for the operator to select the proper file. I know how to copy files from the FTP using the "FTP Get File" VI. However, I need the user to be able to select which file should be copied. The FTP is added as a drive onto the computer but I can't select a path over this route.
Does anyone have an idea?
04-03-2019 08:01 AM - edited 04-03-2019 08:02 AM
Hello Slaxx,
Have you tried the path to string function to convert a path to the string address that you want?
I don't know if it works or not.
04-03-2019 08:18 AM - edited 04-03-2019 08:19 AM
Hello HoussemeddineSnoussi
Thank you for your help. That was my idea first as well. But the problem is the Path Browser won't even let me select a file on the FTP-Drive.
04-03-2019 09:59 AM
There is an FTP Put and Get example in the Example Finder under Help >> Find Examples.
Get going with G! - LabVIEW Wiki.
17 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
