Selecting a particular excel chart
Hi all,
I have problem with selecting a particular chart from a set of 5 charts in one sheet. After activating I need to write some series
into the chart's Y values for plotting. The chart is XY chart.
I tried to simulate this macro in Labview through activeX,
ActiveSheet.ChartObjects("Chart 2").Activate
    ActiveChart.ChartArea.Select
It does not work. Initially chart 5 is activated.
Take a look at my attempt.
Also, see the excel attached. I need to select any chart from that group.
Message Edited by Halemani on 10-03-2008 04:47 AM
Message Edited by Halemani on 10-03-2008 04:48 AM
I have still not got what I love.....
(3,248 Views)
Sorry about the picture. Here is the new one
Message Edited by Halemani on 10-03-2008 05:14 AM
(3,239 Views)
You need to wire the Excel._Chart as the target data type.  Then follow that with the Invoke node SetSourceData.
Michael Munroe, CLD, CTD, MCP
Automate 1M+ VI Search, Sort and Edit operations with Property Inspector 5.1, now with a new Interactive Window Manager!
Now supports full project automation using one-click custom macros or CLI.
(3,210 Views)
Hey Micheal,
I tried doing that but the activate doesn't show up in the property or invoke nodes, strange!
So, I figured an another solution! I recorded macros to activate each sheet and then ran those macros from labview. That's it, it is working.
So, I guess macros come in handy!
Thanks anyways Micheal. Tata...
(3,195 Views)
