Selecting listbox item with right mouse click
I have a listbox control with non editable items.  Is there an easy way to select an item with a right mousebutton click (Like the left click)
(3,166 Views)
Accepted by Franzo
Create an Event structure and generate an event on the Mouse Down? event.  Then use the Button terminal to determine if the right button was pressed.  If it was then set the value of that listbox to the row that the mouse is over.  You can do this using the invoke node Point to Row.
(3,162 Views)
Thank you,  invoke node Point to Row does the work.
(3,154 Views)
