Selecting listbox item with right mouse click
I have a listbox control with non editable items.  Is there an easy way to select an item with a right mousebutton click (Like the left click)
(3,015 Views)
Accepted by topic author Franzo
Create an Event structure and generate an event on the Mouse Down? event.  Then use the Button terminal to determine if the right button was pressed.  If it was then set the value of that listbox to the row that the mouse is over.  You can do this using the invoke node Point to Row.
(3,011 Views)
Thank you,  invoke node Point to Row does the work.
(3,003 Views)
