Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
Selecting multiple files
Eric Inazaki
Member
05-27-2002
05:37 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
Is there a way to select multiple files via a dialog box?
The file i/o VIs don't seem to have the capability to shift-
select files.
TIA
eric
0
Kudos
Message
1
of 2
(3,085 Views)
Reply
Re: Selecting multiple files
Enrique
Active Participant
05-27-2002
07:39 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
eric;
Apparently not.
There is a work around provided by National Instruments. Check the
Multiple File Selection Dialog Box
example located at NI Developer Zone.
I don't know if this is solved for LabVIEW 6.1.
Regards;
Enrique
www.vartortech.com
1
Kudo
Message
2
of 2
(3,085 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
