Selectively applying array elements
In the below program, I would like to be able to select array elements that are passed at the output of the Build Array VI. For example, for one execution of the program I would use all 4 elements (0, 1, 2, 3), but for the next execution of the program, a control at the front panel would allow me to only use only two of the elements (0, 1), without deleting any of the code that isn't being used for that execution.
Thank you for any help achieving this.
(1,420 Views)
You can use Array Subset to get the portion of the array you care about.
(1,401 Views)
Accepted by topic author tareyes
Hi tareyes,
this code basically the same as yours:
(1,374 Views)
