Self-correlation function to calculate speckle size of an image
I conduct research that involves images that incorporate speckle, and I need a program that is a self correlation function that can help me calculate the speckle size of an image. Is there any way that I can do this with labview or has someone already written a profram for it?
(3,067 Views)
If you can describe the algorithm, particularly if you have code in Matlab or a similar programming language that accomplishes what you need, then almost certainly you can do it in LabVIEW.  All you need is someone with some experience with LabVIEW (or someone with reasonable experience in another programming language willing to take the time, typically a few days, to go through the LabVIEW Tutorials and learn how LabVIEW works) and the algorithm.
Bob Schor
(3,062 Views)
