communication IP with cRIO fpga
hi
i used cRIO 9068 fpga and i have smart compteur  connect in my cRIO with IP adress
i want to asek if it is possible to read and write data from compteur with fpga ??? it is possible to read data from ip connect  with fpga ?
thanks for help
(2,823 Views)
If I understand you correctly you want to program the FPGA of the Compact RIO from your PC. Yeah is completely possible. You can follow this link that is a basic tutorial for this:
https://learn.ni.com/learn/article/getting-started-with-compactrio-hardware-and-labview
Randy @Rscd27@
(2,789 Views)
