‎04-26-2015 06:55 PM
‎04-26-2015 07:11 PM
hexadecimal is just another way to format binary codes with 2 characters as opposed to 8 1's or 0's.
‎04-26-2015 07:14 PM
‎04-26-2015 09:24 PM
‎04-27-2015 12:50 AM
‎04-27-2015 07:31 AM
‎04-27-2015 07:33 AM
‎04-27-2015 09:06 AM
‎04-28-2015 12:30 PM
I am still thinking of a way to make it work. But i have another concern? How do i modulate the IR signal at 38 KHz in labview?
‎04-28-2015 12:50 PM
You won't be able to do that within LabVIEW.
USB-6008 has software timed digital I/O. No way you can guaranteed the changing of a digital output at 38,000 times/second with software.
You need a DAQ device that has hardware timed digital outputs. You' then set its clock for 38 kHz and would write a digital waveform for its digital output channel.
