Send IR signal
excuse me if i am wrong, when i did some research on the format of IR codes, it looks like it is in HEXADECIMAL format. how can i output it from NI usb 6008?
Message 11 of 26
(2,532 Views)
hexadecimal is just another way to format binary codes with  2 characters as opposed to 8 1's or 0's.
Message 12 of 26
(2,528 Views)
Okay. So how do i output this binary data? Just by giving output high and low and delay in between? Please give me a solution. I am not so good at this.
Message 13 of 26
(2,526 Views)
Yes, that is exactly how to do it.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 14 of 26
(2,498 Views)
is it possible to do with pwm?
Message 15 of 26
(2,481 Views)
This will work with anything that uses a series of digital on an off states. But I thought you were controlling a fan?
Mike...
LabVIEW Champion
Message 16 of 26
(2,460 Views)
I am. The device that i control is a fan. Do you have an example code to send this kind of data?
Message 17 of 26
(2,458 Views)
No, but I have already told you how to proceed.
Mike...
LabVIEW Champion
Message 18 of 26
(2,444 Views)
I am still thinking of a way to make it work. But i have another concern? How do i modulate the IR signal at 38 KHz in labview?
Message 19 of 26
(2,420 Views)
You won't be able to do that within LabVIEW.
USB-6008 has software timed digital I/O.  No way you can guaranteed the changing of a digital output at 38,000 times/second with software.
You need a DAQ device that has hardware timed digital outputs.  You' then set its clock for 38 kHz and would write a digital waveform for its digital output channel.
Message 20 of 26
(2,418 Views)
