Send SMS using an ordinary Mobile Phone
Got busy in some other activities and now working on the task.
I was succeeded in sending sms using the AT Commands help given in the pdf document through Hyperterminal.
Now trying the same thing with labview. I could not get the results
i.e. i was sending AT from the PC but getting AT again inplace of OK when reading the port.
I couldn't understand where the actual problem lies.
Anyone may please guide.
Message 11 of 29
(1,450 Views)
Message 12 of 29
(1,449 Views)
Hi Intelligent,
which termination char do you use in hyperterminal? You should use the same in LabVIEW.
Mike
Message 13 of 29
(1,445 Views)
Actually i wrote AT to the bus and tried to receive OK from it.
But it could not work in LabVIEW.
But as a response i get AT from it.
I dont understand it's reason.
Message 14 of 29
(1,443 Views)
try it with \r\n (code display) as termination char.
Why don't you read the entire data from the serial interface? I think, if you would read the entire response, then you could see the needed termination character.
Mike
Message 15 of 29
(1,440 Views)
Tried to read 4 characters from the port but only two characters were received which were same as previous i.e. AT.
As you advised to use the termination character, i found unable to enter \n or \r. As the fields of entry were limited to hex, octal, Decimal, binary and SI notation.
Message 16 of 29
(1,436 Views)
you can switch the termination char off and add "\r\n" (still in code display) to your AT command (in the string).
Mike
Message 17 of 29
(1,431 Views)
Changes into a broken wire.
Also attaching the file for your kind refrence.
Message 18 of 29
(1,424 Views)
see the attachment please.
Mike
Message 19 of 29
(1,421 Views)
"AT/r/n" are now seen in the read.
Hence what is send is received.
File also attached
Message 20 of 29
(1,416 Views)
