Send and Receive data Through Ethernet Port?
     I am trying to acquire details of the LAN/Ethernet details from PC through LabVIEW.Like we get the system date&time,Serial Port etc, is it possible to get the LAN Details of my PC Through LabVIEW.My aim is to sebd and Receive command through Ethernet Port.
(6,281 Views)
Which lan details are you after? for some of them calling a dos command via system exec.vi then interpretting the output may help
Please remember to accept any solutions and give kudos, Thanks
LV 8.6.1, LV2010,LV2011SP1, FPGA, Win7
(6,269 Views)
I want to send a command through ethernnet port for recieving the data.Which one should i use client.vi ore server.vi in TCP/IP Communication???
(6,266 Views)
Accepted by $agar
Last time i did it i used the tcp pallete. (i go ctrl+space for the quick drop menu then type tcp.) open a conection to the network device then use tcp read/write as appropriate. there are examples as well that can be quite useful
(6,259 Views)
