Send counter/digital outputs while acquiring analog data
Hello all
I have attached what I came up with for a program, that as far as I know would work for this application.  Because I am still learning, If someone out there who knows this better than I would like to take a look at this program, I would really appreciate it.  Dansch, I took your advice on creating the waveform arrays for the digital triggers, and that seems to work just fine.  The actual program requires three triggers and four analog inputs that acquire data simultaneously, so that makes it slightly more complicated than before.  The VI and SubVI's are attached.
Happy Holidays
Chris
Message 11 of 12
(673 Views)
I don't seem to have the Waveform Trigger VI from your code in the zip file so cannot fully evaluate your code but it looks pretty good.  One thing I would mention is that you are missing a Start VI before your Read VI.  I would also wire the error line from your last Waveform Trigger VI into the missing Start VI in trying to keep as close as possible to Dansch's example VI (attached below again for ease of reference).
Doug Farrell
Solutions Marketing - Automotive
National Instruments Automotive Solutions
Message 12 of 12
(642 Views)
