Send email on labview using the Gmail Server (TLS)
Kimse,
It sounds like you are having a relatively unique issue. If I could get just a bit more information, I think we can maybe get this taken care of.
1) Which windowas are you using? 64 bit or 32 bit?
2) Which labview 2009 are you using? 64 or 32 bit?
Could you do me a favor and open a blank VI, put a .net object onto the VI, such as a Rich text box, under the .net & ActiveX palette. Does labview crash? What about if you create a .net constructor node (of any type)?
You may also be interested in this Knowledgebase article discussing a similar problem :
http://digital.ni.com/public.nsf/allkb/60ECB95AD61660338625712500831AEE?OpenDocument
Kyle Mozdzyn
Applications Engineering
Kyle M.
Message 71 of 114
(3,444 Views)
Kyle
I am using windows 7 64-bit.
And i use labview 2009 32-bit
when i wanted to put Rich text box (from .net & Activex panel) , again labview itself. or when i wanted to put mathcalender or picture box again it closed itself..
it didnt close itself when i used others in .net & active palet, like activex container, .net container, web browser, windows media player.
Message 72 of 114
(3,436 Views)
Kimse,
Your system is giving a crash symptomatic to a fundemental issue between your .net and labview communications. Is there any way I could get you to produce a dump log for the crash and attach it here?
Youll need this microsoft utility (userdump): http://www.microsoft.com/downloads/en/details.aspx?FamilyID=E089CA41-6A87-40C8-BF69-28AC08570B7E&amp...
Instructions for dump file generation can be found here: http://support.microsoft.com/kb/241215
Kyle Mozdzyn
Kyle M.
Message 73 of 114
(3,421 Views)
Kimse,
Disregard the previous post please, I have found a few simpler steps we can do beforehand.
You can try a repair install (which is different than a re-install) by following these instructions:
http://digital.ni.com/public.nsf/allkb/FE6B641E86E55AF2862576DE00038001?OpenDocument
you may also be able to pull a useful dump from documents>>Labview Data>>LVfailurelog
regards,
Kyle Mozdzyn
Kyle M.
Message 74 of 114
(3,413 Views)
i tried what u said on your last message, it didnt work.
there wasnt a file like LVfailurelog.
thanks
Message 75 of 114
(3,396 Views)
Hey Kimse,
   Can you try the crash dump process that Kyle M mentioned on the post previous from LVfailurelog.
Jig P
Best Regards,
Jignesh Patel
Principal RF Software Engineer
Message 76 of 114
(3,361 Views)
yes i created a dump file of Labview as the following web page. or should i choose something else to creat dump file?
dump file LABVIEW.DMP is 189 mb.
http://support.microsoft.com/kb/931673 (because when i tried to creat with another page it didnt work, i think another page wasnt for windows 7)
thanks for your helps
Message 77 of 114
(3,331 Views)
some files near LABVIEW.DMP
Message 78 of 114
(3,324 Views)
Hi Kimse,
    You may have to do one of two things. Try repairing your .NET assembly from contol panels. Also are you using LabVIEW 2010 or LabVIEW 2010 SP1?
Regards
Jignesh P
Best Regards,
Jignesh Patel
Message 79 of 114
(3,294 Views)
i repaired .NET 4, nothing changed. I use labview 2009
Regards
Message 80 of 114
(3,275 Views)
