Send information from labview to arduino
Wondering,
is there a block that i can send inputs from labview into arduino to control say a PWM of a motor?
I dont want to use LIFA was hoping to do this over com ports
(3,122 Views)
Accepted by topic author xxAddictionxx
Hi xx,
yes: VISAWrite!
You need to implement a sketch on your Arduino that is able to handle your request…
(3,114 Views)
I'm using lifa for a while and I think that it is well done. So I don't understand why you dont wanna use it.
"I dont want to use LIFA was hoping to do this over com" -Lifa is a serial communication.
Use it as a template and modify it. It better and faster.
Be,
Jorge Amaral
Software developer
www.mcm-electronics.com
PORTUGAL
(3,098 Views)
LIFA is well made. I have used it and had much success with it.
However for transportability LIFA is not so simple when other people do not have it installed and want to stay away from it because of the lack of understanding.
Thus the main reason for Arduino is transportability and not having to download any extra addons.
(3,093 Views)
what about the MakerHub Linx project? Isn't it a solution for you?
https://www.labviewmakerhub.com/doku.php?id=libraries:linx:start
Regards
Kay
(3,079 Views)
Do not bother answering here as the OP has written yet another post on the same topic!
https://forums.ni.com/t5/LabVIEW/VisaWRITE-to-Arduino/m-p/3847263/highlight/true#M1089006
(3,058 Views)
@kaba2005 wrote: what about the MakerHub Linx project? Isn't it a solution for you?
Linx is just a newer version of LIFA.  So it does not exactly meet what the OP is after.
But, yes, use VISA Read and VISA Write to read and write data from and to an Arduino.  You will need to create your own serial message protocol and implement it on both ends.
(3,057 Views)
