Sending/Receiving data with LabVIEW via SPI from a I/O card
Is it possible to invert the Sample clock? At the moment I read data with the negative edge of the SCLK (my sample clock), but I would like to read also with the positive edge. Is it possible to invert or shift the sample clock for my needs?
Thank you
Christoph
Message 11 of 15
(1,403 Views)
Hello Sierra Kilo,
you can invert the Edge the Sample Clock by wiring the "active edge" Input of the DAQmx Timing VI with a Constant set to "Falling"
Regards
Moritz M.
Message 12 of 15
(1,399 Views)
Ah perfect, sometimes the solution is so near! 🙂
Regards
Chris
Message 13 of 15
(1,394 Views)
The problem with sample clock is that it is always running.  What I did in the past was to create my own SCLK, SDO, and CS as follows:
Bit 0 is dedicated to SCLK, Bit 1 to SDO, Bit 2 to CS, and Bit 3 to a flag (I'll explain later).  Use a 1D array to hold the data that you will write to the DIO port.  Lets say you want to write 10101010 to the SDO line.  Form you array like this:
Bit 0 ---> Bit 3 (SCLK, SDO, CS, Flag)
0000 - sets CS low
0100 - sets the first SDO bit
1100 - clocks the first SDO bit
0000 - clock low, set next SDO bit
1000 - clock the next SDO bit
0100 - clock low, set next SDO bit
1100 - clock the next SDO bit
continue on until all SDO bits have been clocked.
Now to read SDI:
1001 - clock high causes device to send SDI, also set flag bit high
0001 - clock low
continue on until 8 clocks have been sent.
Now take your read buffer and extract only the lines where the flag bit is high.  This gives the data returned from the device.
Of course this will reduce your SCLK rate to half the sample clock rate.  So set you sample clock to twice the frequency of your intended SCLK rate.
There are SPI cases where you can send data and receive data at the same time.  Send command 1, then send command 2 and receive response 1 at the same time.  If you use this scheme, you don't need the flag bit.  Just ignore the first byte you receive.  Also, if you use this scheme, you can invert the SCLK bit to clock on the negative edge.
I hope this all makes sense.
- tbob
Inventor of the WORM Global
Message 14 of 15
(1,379 Views)
@@ SierraKilo,
I am also working on same application. Could you please let me whther you find solution.
Upto wht frequency have you tried?. Appricite in share some more knowledeg or VIs.
Message 15 of 15
(1,150 Views)
