Sending a hexadecimal command through Modbus Ethernet
I want to use the Modbus Ethernet Master Query Write function to send a hexadecimal command over ethernet. My problem is that the registers are numeric u16 and thus won't accept letters, but my command contains letters. As a hex my command is 4B 52 44 47 3F 20 30 0D 0A, so each pair is in one register, so I need to be able write a mixed number and letter in some of the registers. Is there a way to do this?
(6,837 Views)
You could write
19282 = 0x4B52
17479 = 0x4447
16160 = 0x3F20
12301 = 0x300D
2560 = 0x0A00
to 5 U16 registers.
Regards, Jens
Kudos are welcome...
(6,817 Views)
Accepted by Nadweb
Make your control or constant show the radix.  Set it to be Hex display.  Now you can type those hex values in using 0-9,A-F.
(6,796 Views)
Hi Nadweb,
You can also use a string constant like this:
Are you sure it's a "hex command for Modbus"?
(6,787 Views)
I guess its a string serial command, KRDG? 0\r\n, that I have converted to hex for use with modbus tcp/ip
(6,770 Views)
Modbus TCP/IP does not have any "commands" that look like that.
Perhaps you mean just TCP/IP communications with an instrument.  But it is not Modbus.
You can find details about Modbus communication here.  https://modbus.org/tech.php
(6,767 Views)
It is an instrument specific RS232 command that I would normally send as a string using VISA write, so I was incorrect calling it a Modbus command. My understanding from the application engineer is that I can convert this command to a hex, and send it via Modbus TCP/IP Ethernet to our programmable automation controller, which should be able to send this to the instrument and read the response, via a boot program. I am very new to Modbus, so I'm learning as I go.
(6,762 Views)
