Sending data to 2 UDP port at the same time
I'm writing an application that writes data to 2 UDP port at a speed of 4 Mbit.
The first thing I do is open the 2 UDP (with the UPD open vi). Then I send the data with the UDP write vi. The problem is that I sometimes receive an error 55 message (The network operation is in progress) while sending the data to the udp ports. The program works with sending data to 1 UDP port. I only get the error55 while sending it to 2 ports. I'm sending the same data to 2 port using the UDP write vi 2 times in a row (just first send the package to the first UDP port and then send the package to the second UDP port with the error clusters connected to each other).
I checked the NI site and there they mentioned some sort of multicast
UDP vi but I could not find the vi.
Can somebody help me with this problem?
thank you,
kind regards,
Marino
(3,244 Views)
Do you "udp open" only once and then wire both "writes" to the same connection ID???
Instead, do two UDP open, one for each destination port, and use a different local port for each. According to my casual testing, this should solve your problem.
(see also attached image. If you are already doing this, please post your example.)
(Btw: Multicast is a matter of destination address, not port, and probably will not help you. UDP multicast is supported in LabVIEW 7)
(3,244 Views)
