 johnydang
			johnydang
			06-11-2024 10:14 AM
I'm new to labview. Currently, my program read multiple signals from sensors with different frequency and then signals are saved to csv file. I want to send these signals to the internet also. Which protocol should I use (MQTT or something else). How can I send these signals with different frequency to the internet? (should I have to create multiple while loop structure to send data for each signal?)
			06-11-2024 10:52 AM
Hi johny,
You don't "send to the internet"…
There are two options:
What do you want to implement?
Where do you want to send data to specifically?
Which format/protocol is expected from those possible clients or server?
06-11-2024 09:10 PM
Hi GerW, I am thinking to send data to aws and use the grafana dashboard to show the real time data of the signal. I'm not sure which protocol should I use yet. I want to send the signals to aws parallelly with different sampling rates. My consideration is how to organize the labview program to do that ( is it supported multithread or is there any example similar to this case). Thank you very much for your reply
 santo_13
			santo_13
			06-11-2024 10:01 PM
What will be the data storage mechanism? some sort of database on AWS?
In short, you will publish data from your LV application to a data repository on AWS, then Grafana dashboards can be used to view the data from this data repository.
I would recommend considering NI SystemLink if you have the budget.
