Sending one byte with Rs232 ?
I have a device, which works with 1-byte commands.
example:
0xD1 has to be sent, where the high nibble (D) is one of six commands and the low nibble (1) is one of 15 possible addresses.
Commands are: E,C,D,8,5,4
Addresses are: 1-F
There are 90 possible combinations of commands and addresses.
I made a program, where i can choose the command and the address separately, and they will be combined individually in one string, which should be one byte.
Now the problem:
If i send this string via RS232 to a PC-Terminal, i see exakt the same string as in my program.
>> 0x51 should be the combined string and I want to see a "Q" at the terminal but the result is "51".
There are sent two bytes (0x35 and 0x31 for "51") than one 0x51 "Q".
When I make a Stringelement (with property "HEX-Display") and typing in the number (51) directly, i get a "Q" on the terminal.
How can i automate this?
I really spent a lot of time on this problem!
(3,076 Views)
Here is the program
(3,065 Views)
See attached vi.
Hope that helps.
Neil
(3,058 Views)
Thank you very much!!
This is exactly what i was looking for.
Markus
(3,053 Views)
I hope you don't mind, but I took the liberty of modifying the block diagram to make it much more readable, and I got rid of the local variable which is unnecessary. Compare this block diagram to the one using the sequence structures. In this diagram, all of the code is visible at one time. The data flow insures that the funtions will operate in the correct order. This is the preferred method of coding over using sequence structures.
- tbob
Inventor of the WORM Global
(3,040 Views)
