Sense Run-Time or Development Environment?
Hi Gang,
I want to use case structures in my app depending on whether the app is running under LV or is compiled and running under run-time. How to quit the app being a prime example.  I've found an application property called "application property environment mode," but it doesn't seem to return anything.
I'll appreciate all enlightenment.
Roger
(3,224 Views)
Accepted by RogerMont
Use the Applications.Kind property.
(3,221 Views)
Thanks, Dennis!
Roger
(3,204 Views)
