Separate 16bit hex data
I want to separate 16bit Hex data in groups of 4 bit i.e. if I input ABCD, the output should be A, B, C, D.
The idea I am thinking of is to do bitwise AND and do masking with 0xf, 0xf0, 0xf00 and 0xf000, but I am not able to implement it.
Please help me regarding this.
(3,275 Views)
Hi ravi,
to implement an AND function I would use the AND function:
The loop above shows an alternative way…
(3,272 Views)
Thanks a lot GerdW..
Ravi
(3,250 Views)
Hi ravi,
in my snippet above I forgot to wire a "4" to the FOR loop N terminal…
(3,248 Views)
No problem Sir, I had got you idea and modified it according to my use.
Ravi
(3,246 Views)
