Separating array of cluster into 2 different arrays
I have an array of 5 cluster elements. Each cluster has 1 string and 1 numeric. I have been trying to separate them into 2, one containing only the string values and the other only numeric values. It can be anything either an array or a cluster. How can I achieve this? I have been trying different methods with build array, insert into array etc. But none of them is giving me the final output that I require. Kindly do help me.
(4,493 Views)
Can you post a screenshot of your array of clusters?
My Channel: https://www.youtube.com/@LV_Lab
(4,482 Views)
Accepted by topic author govindsankar
This may be what you need. Use a For Loop to unbundle your clusters and create the arrays.Array of Clusters to Array.png
Founding (and only) member of AUITA - the Anti UI Thread Association.
(4,479 Views)
Hi Govind,
This is a very basic use of for loops
(4,476 Views)
I hope its very basic and many commented the solution, if you are new to LabVIEW please go through basic online LabVIEW Tutorial and Understand More about structure's and Loops.
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
(4,425 Views)
