Seperate start stop button for analog output
Hi here i need to create analog output with start, stop and reset button i have attached vi here take a look at this i want to start sending the analog output and i need to stop at certaian value and i again i need to start and also i reset button but in the vi i made it was not working properly is there any other method to do this, need some ideas here quickly,
Dinesh
Message 1 of 16
(4,278 Views)
I am not sure, if I understand your problem from your description. Can you explain the goal here?
Martin
Message 2 of 16
(4,273 Views)
Actually when i press the start button it should start sending the signal i mean if i enter voltage 1 or 0.1 from that second it should start send the signal if i again press stop it should stop and if i press the reset button the sending voltage should come to zero and if i again enter the start button the iteration should start with initial value 1
Message 3 of 16
(4,261 Views)
Sorry to say that i need some ideas quickly
Message 4 of 16
(4,259 Views)
Hi dinesh,
implement a state machine when you want to execute certain states based on conditions (aka boolean buttons in your case)!
Btw. NEVER delete the labels of controls/indicators!
Message 5 of 16
(4,241 Views)
is there any chance i could do simply now i need to submit a report tomorrow well i'm not familiar with state machine program much
Dinesh
Message 6 of 16
(4,235 Views)
Hi Dinesh,
Well, surely there is a (light) chance to go there without a state machine.
When you want to have a scalable, (hopefully) well documented code you should implement a state machine. That's my recommendation!
And it always helps to plan your algorithm on a sheet of paper before starting the actual coding work!
Message 7 of 16
(4,227 Views)
 i have created this vi to start and stop the analog output voltage and also i can reset it but when the output reaches max voltage it was not reinitialise to zero
Message 8 of 16
(4,177 Views)
Message 9 of 16
(4,191 Views)
Hi dinesh,
Where exactly did you program this requested feature?
The VI will only do what you have it programmed to do…
Suggestion:
IF actual voltage >= max voltage THEN actual voltage := 0
Message 10 of 16
(4,168 Views)
