Seperate start stop button for analog output
can you give example programmatically?
Message 11 of 16
(795 Views)
Hi dinesh,
it's a shame you ask for an example of a comparison and an IF-THEN-ELSE (aka case structure or Select function):
Message 12 of 16
(788 Views)
actually my point is it should not automatically goes to zero only when user enters the reset button it should initialise to zero and also in my case it was already working but when it attains the max value and when i press the reset button it was not going back to zero
Message 13 of 16
(784 Views)
Then add code so that the reset happens when the output is greater or equal to the max value.
Message 14 of 16
(794 Views)
    It worked perfectlt now it was stopping at maximum value and also i can reset it to initial voltage.
Thank you so much for your contribution
Dinesh
Message 15 of 16
(762 Views)
     Now i can actually stop the value at maximum point and also i can reset it to initial value.
Thank you so much for your contribution here,
Dinesh
Message 16 of 16
(763 Views)
